Hello Guys,
New to this forum.
I have a 2011 Cascadia DD15 that have an A/C issue.
It had a leak on the evaporator, we replaced it and charged it back with almost 5 lbs of freon and test it for leaks, but now the compressor doesn’t want to kick in.
I reset the a/c but didn’t work, the compressor did work when i connected the power directly from alternator.
Any advice on what could it be?
Thank you!
2011 Freightliner Cascadia A/C Problem
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by cmcinc, May 22, 2018.
A temp sensor on the evap. can stop a/c comp from coming on, the work you had done may have left a wire not reconnected on temp control sensor?
otterinthewater Thanks this. -
Thank you! -
It was on theLeft top side of box pointing down into evap on older year cas. it has a small plug in wire that must be conn. for a/c to work
A/C running good now.
