2011 Mack CXU ABS codes MID 77 FMI 7
Discussion in 'Mack Forum' started by A Keffer Inc., May 3, 2021.
  1. A Keffer Inc.
    A Keffer Inc. Bobtail Member
    27
    7
    Aug 5, 2010
    Moyock, NC
    Hey guys. I have two ABS / TCS that I can't seem to figure out where to look. My understanding is that the codes stand for Brake Load Demand (or command) but I don't know where the sensor is located.
    These are me two codes:
    1. ABS (136) SID 78 FMI 2
    2. ABS (136) SID 77 FMI 7
    Both of these codes are slightly de-rating my trucks HP / Boost.
    Anyone know if these are air pressure sensors located at the brake pedal (4 sensors inside the cab around the treddle valve / two located under the hood under on the treddle valve. Or are these the sensors that attach to the rear suspension air bags ( two- one on front axle and one on the rear axle)
    Thanks for the advice.
  3. QUALITYTRUCK
    1,821
    1,789
    Jun 14, 2009
    romulus,mi
    I bet it is/was raining heavy when this happened? Steer axle sensors are too wet causing erratic readings. When they dry a little more I bet it will clear codes on its own.
  4. A Keffer Inc.
    27
    7
    Aug 5, 2010
    Moyock, NC
    It's been an on going problem even in dry weather. Are these codes relative to front ABS WSS?
  5. A Keffer Inc.
    27
    7
    Aug 5, 2010
    Moyock, NC
    Just found this:
    Sid 78 Fmi 2: Brake Demand / Load Sensor DTCs / Shorted Brake Demand Sensor (secondary CKT) OPEN
    Sid 77 fmi 7: Brake Demand/ Load sensor DTCs / PS not Calibrated
    So is it the air pressure sensor by the Brake valve inside the cab that says secondary air? Or one that's on the outside of the firewall? Both says secondary system so not sure with one to look at??
