Hi,
Have a 2011 volvo with a d13. Had wiring harness replaced. Then mechanic put a new oil cooler gasket replaced the new upgraded version with the new model due to engine coolant leak. Replaced every hose and turbo instaliation kit and every gasket on the right side. Mechanic says truck is ready and know it has a big diesel leak behind turbo and exhaust. Mechanic says that they only way he could fix the problem is if he deletes the dpf and def?
Any advice on what to due truck has a week at the shop.
2011 volvo d13 Issue?
Discussion in 'Ask An Owner Operator' started by 88 v13, Oct 5, 2017.
Get a lawyer for what?
88 v13 Thanks this. -
I think what I looked up it is a 7th injector near or on doser?
The lawyer idea is that a good option? -
The 7th injector injects the urea into the exhaust post turbo to help burn off the emissions. It has nothing to do with diesel. It's a relatively easy replacement. Either you aren't understanding the mechanic or he doesn't know what he is talking about.
88 v13 and Socal Xpress Thank this. -
88 v13, shogun and Socal Xpress Thank this.
Mechanic Fixed Diesel leak. But know Truck when shifting there is a noise whistle of maybe air near turbo. Or when you Rev the Engine you could hear the noise after the Rev.
