2012 FL Cascadia wont stay running in neutral
Discussion in 'Experienced Truckers' Advice' started by RORAY, Feb 16, 2020.
  1. RORAY
    RORAY Bobtail Member
    It keeps blowing fuses, and giving CAB33 code. Now it shut down while driving. Any suggestions on what my problem is?
  2. Moosetek13
    Moosetek13 Road Train Member
    10,332
    9,090
    Nov 1, 2010
    Burnsville, MN
    Sounds like something may be amiss.
    The shop could probably pinpoint the problem a lot better than the peanut gallery.
  3. AModelCat
    60,577
    The North
    Trace whatever wire/harness that fuse is connected to. Usually fuses blowing indicates the wire has rubbed thru against something metal or another wire if 2 circuits are acting wonky.
    magoo68 Thanks this.
  • Draft saved Draft deleted
