2012 VNL d13 fuel in oil
Discussion in 'Volvo Forum' started by Imani100, Sep 11, 2022.
  1. Imani100
    Imani100 Light Load Member
    116
    27
    Mar 12, 2017
    Chicago
    Hey, i have a 2012 Volvo VNL 670 D13 w/ about 680k miles, i run local containers and I’m having some fuel in the oil at about 8k miles which causes the engine to stall then i get a oil change and it’s runs fine i plan to get it in the shop asap. Any input?
    things replaced:
    Injectors&cups 130k miles ago from Volvo dealer
    Turbo&vgt 30k miles ago
    shop has checked the oil and fuel pump before and said it was fine, is it possible for the fuel filter housing to be faulty?
    i uploaded a pic of the fuel filter housing not sure if that looks like it’s leaking next to where you prime it.
    I’ve also had oil leak into the coolant before but had that all repaired at the dealer also
  3. Imani100
    116
    27
    Mar 12, 2017
    Chicago
  4. Judge
    70,577
    Newport, Ar
  5. nasriza
    nasriza Road Train Member
    2,366
    2,039
    Feb 1, 2013
    Chicago, IL
    You fuel leak is in the engine internal either injectors leaking to crankcase or head no other point in d13 that fuel and oil meet besides in the engine, fuel pump has no clear path to crankcase so it can not leak there, look at injector leaking fuel external to the crankcase and draining down in the oil system have seen this a #### ton of times.
  6. Imani100
    116
    27
    Mar 12, 2017
    Chicago
    Injectors again at less then 140k miles that sucks thanks I’ll check
  7. nasriza
    2,366
    2,039
    Feb 1, 2013
    Chicago, IL
    Not all prob bad 1
  8. Imani100
    116
    27
    Mar 12, 2017
    Chicago
    do you know how much that cost? I had mine done in 2018 but i run local so my miles go up pretty slow
  9. nasriza
    2,366
    2,039
    Feb 1, 2013
    Chicago, IL
    Well injector probably around 550 my guess to find the problem and find which one is leaking that will be probably more money should be able to be in and out for around 1500 to 2000 but depends on where you take it to.
  10. Imani100
    116
    27
    Mar 12, 2017
    Chicago
    Yeah all the shops here In Chicago seem pretty busy this week i guess I’ll try next week
  11. nasriza
    2,366
    2,039
    Feb 1, 2013
    Chicago, IL
    I can do it this week if you are willing to drive to west chicago.
