2013 CASCADIA. Extreme front end death wobble
Discussion in 'Freightliner Forum' started by irishluck09, Aug 15, 2026.
  1. irishluck09
    irishluck09 Medium Load Member
    330
    200
    Nov 24, 2019
    I am trying to narrow down this issue on my cascadia.
    Tired are good and newer. Brand new tierod ends and bar, new drag link. Truck had an alignment done on it and it has a very extreme death wobble at like 45 mph.
    You can physically see the steer tires move left and right when driving, both sides.
    This problem started happening after the truck got greased.
    No slop in kingpins.
    What am I missing here?
  3. Magoo1968
    Magoo1968 Road Train Member
    2,168
    5,783
    Mar 18, 2021
    St Malo mb
    We get that issue when the beads the company uses in the steer tires lump up. Drivers hate the beads but boss believes the shop foreman that they work the best even though they need to pop tire and dry them occasionally mostly spring and early winter.. same speed 40 to 50 max it clears up after.. not sure what you balance with but that’s my first guess on the shake..
  4. irishluck09
    330
    200
    Nov 24, 2019
    so think its the tires or the balance on the tires?
  5. Magoo1968
    2,168
    5,783
    Mar 18, 2021
    St Malo mb
    Balance on the tires . Cascadias shake like crazy if steers are out of balance enough. Is it possible a balance weight fell off
  6. Diesel Dave
    10,102
    36,113
    Jan 20, 2010
    Hesperia, Ca.
    I had a similar issue, brand new Kelly steer tires, one was out of round. It would the same as you described, same speed.
    Magoo1968 Thanks this.
  7. irishluck09
    330
    200
    Nov 24, 2019
    Im gona take a set of tires of one of my other trucks and see if that fixes it
  8. Star Rider
    Star Rider Road Train Member
    1,899
    21,930
    Sep 23, 2019
    Jack up one front wheel and place a spray can close to the front of it, like 1/8 of an inch
    Spin the wheel and you can see if the tire is out of round.
    Do this on the sidewall of the tire also.
    Do this on the other side.
    If the tires check out after this then do your swap and see.
    Diesel Dave, Speedy356 and Magoo1968 Thank this.
  9. 201
    201 Road Train Member
    13,012
    26,856
    Apr 16, 2014
    high plains colorado
    Don't forget wheel bearings do funky things, but more than likely a tire. If you ever hit a curb or big pothole, the belts can break and never get it balanced.
    Star Rider Thanks this.
  10. irishluck09
    330
    200
    Nov 24, 2019
    WEll that was definitely it!
    Steer tires it was. Guessing broken belts like it was mentioned. I just couldn't imagine that would have caused such a bad death wobble.
  11. Diesel Dave
    10,102
    36,113
    Jan 20, 2010
    Hesperia, Ca.
    What brand of tires were they ? How many miles on them ?
