2013 Cascadia fuel problems, over fills the drivers side tank.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by bangstick!1, Jan 18, 2021.
  1. bangstick!1
    bangstick!1 Bobtail Member
    7
    Jan 18, 2021
    hello everyone, my 2013 Cascadia has a fuel problem, i bought it used and since ive owned it, i can drive it and it will pull fuel from the pass side tank only, when i fuel, it will over fill the drs tank, if I leave the unit alone over night the tanks will equilize.I checked all the usual problems, fuel caps ,vents and collapsed lines nothing bad. the former owner removed and bypassed the fuel shutoff valves from the factory.no fuel leaks runs great. I cannot seem to figure this out. can anyone of you help?
    petefan4000 Thanks this.
    Trucking Jobs in 30 seconds
  3. Diesel Dave
    5,180
    6,095
    Jan 20, 2010
    Hesperia, Ca.
    I would still focus on the vents/breathers. Remove them and clean them out really good, and blow air in them.
  4. Diesel Dave
    5,180
    6,095
    Jan 20, 2010
    Hesperia, Ca.
    Or maybe the return line. Mine has a splitter for the return.
  5. bad-luck
    bad-luck Road Train Member
    1,560
    2,028
    Nov 16, 2013
    Baltimore, Maryland
    Sounds like the either the pick up line in the tank or the fuel line in the drivers side fuel tank is clogged with debris
  6. bangstick!1
    7
    Jan 18, 2021
    thank you, ive done just that no obstructions i even put on new vents do difference.
    Diesel Dave Thanks this.
  7. bangstick!1
    7
    Jan 18, 2021
    i will recheck. thank you
    bad-luck Thanks this.
  8. bangstick!1
    7
    Jan 18, 2021
    mine has a t fitting i donot know if it is just a brass t or is there a check valve in it
  9. Diesel Dave
    5,180
    6,095
    Jan 20, 2010
    Hesperia, Ca.
    My return line had a factory T-splitter which had a flapper valve in it and it was mounted above the transmission. One day it just started leaking so I just replaced it. When I started getting more fuel in one of the 2 tanks, it was clogged vents.
  10. baha
    baha Road Train Member
    3,584
    2,130
    Jul 25, 2013
    ga
    The splitter diesel Dave is talking about is what puts fuel into one tank and leaves the other side dry when it goes bad, it will be at rear of trans. follow fuel lines to find it, change it out for a new one ,
  11. kemosabi49
    6,666
    21,653
    Jan 13, 2013
    SW Arkansas
    I had that happen on a FLD I had. Turned out there was some crap in the tank that kept getting sucked into the outflow fuel line and plugged it up. So it was only drawing fuel from the right tank but still returning it to both tanks. Ended up getting a used tank because we never could get all of the crap out.
    Accidental Trucker Thanks this.
  • Draft saved Draft deleted
