Check engine light code reading (fail 18 spn 3216 eng 1) I need help I'm totally lost on this one
2013 Freightliner Cascadia engine code problems need help
Discussion in 'Freightliner Forum' started by David allen23, Jun 14, 2019.
Nox sensor issue. Google search says. Are you derated?
Fmi 18 ..no it's not derating .. I just replace my one box in February of this year
One of our guys did a One-Box this year. You only get the box it's self, the sensors are not included. He had a problem shortly after and found out they just put the same old sensors onto the new box. After they changed one of his NOx sensors it was good.
mhyn Thanks this. -
Okay thank you for the information I tried the regen my truck today but it wouldn't do it.. I only have one check engine light on at the moment.
Yhea, the yellow check engine light. Its gonna do like a 30% derate soon. You'll be able to run, but you gonna notice it. I wont bet money, but prolly that Nox sensor. Have a shop with a real computer run a parked regen and compare in and out numbers. Sensor may be just going bad and numbers have drifed out of range. I had them problems aswell on a 2011 i had.
Ok thank you do you remember bout how much it cost you when it happen to you
