2013 Peterbilt 348 keeps blowing air bags
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Davis42200, Dec 11, 2024.
  1. Davis42200
    Davis42200 Bobtail Member
    36
    4
    Dec 7, 2020
    This truck has an air leaf suspension with 4 air bags. I haul scrap metal so the loads do get pretty heavy. I have an international 5900i with a similar air suspension that never pops the bags even when it's overweight by a lot.
    The Peterbilt bags are really tall and set on this little plastic stand. When they pop, it usually sheers the bolt off.
    So my question is is there something that could be causing this other than the weight? Will bad shocks or bad torsion bars cause it to blow the bags? This is a roll-off truck and I do dump the bags when I pickup the loads. They blow while driving at ride height.
    If it's just the weight, is there anything that can be done to beef it up? How much work to change to a solid suspension?
  3. 062
    062 Road Train Member
    6,340
    33,985
    Oct 20, 2013
    If it’s shearing the bolt, then it’s probably a suspension issue,worn bushing maybe.
    Were you the one having trouble getting the bags to inflate?
  4. Davis42200
    36
    4
    Dec 7, 2020
    Yes. That load ended up just being wayyy to heavy.
  5. Davis42200
    36
    4
    Dec 7, 2020
    It's hard with scrap metal because we are not loading the box. It's on site at the customer's location with no scale.
  6. SmallPackage
    5,816
    18,635
    Dec 20, 2019
    Marion Texas
    Is it by chance the lighter duty air leaf without the top track bars? That causes side to side movement on the air spring perches without them.
  7. Davis42200
    36
    4
    Dec 7, 2020
    I'm not a suspension expert. Can you tell me what to look for? Or send a picture
  8. SmallPackage
    5,816
    18,635
    Dec 20, 2019
    Marion Texas
    the bar that is circled in yellow. This one was cut by the scrap yard to remove from frame. The less common lighter duty air leaf does not use this bar.
  9. Davis42200
    36
    4
    Dec 7, 2020
    It does have those. Two of them. I was told to check the bushings in those arms.
    SmallPackage Thanks this.
