2013 ProStar + Sleeper with No Idle HVAC
Ok so my truck has sat all summer long and now we want to head out to the east coast and I ran into some problems. The Cab has no hvac controls, the screen does not light up nor when i hit the buttons on the dash it registers nothing. Also the AC Clutch is not engaging at all. I have Checked all the Fuses and Relays and nothing seems to be blown. Even changed all the 5 amp ones to confirm they were good for the sleeper controls. Can someone please HELP
Discussion in 'International Forum' started by johncatco, Sep 13, 2018.
The no idle system has it own set of batteries and the feed for the sleeper controls come off those batteries and have their own cube style fuse bolted right to one of the positive battery posts. If that control panel is dead, I would say no power is coming from the batteries. The cube fuse is usually ok, but the buss bar it bolts too corroded and breaks off. Check all that and also make sure those batteries aren't actually dead.
I will dig into this asap! It has been sitting for a few months we use it for disaster recovery and with Florence coming in tonight we need to be on the road. I appreciate the prompt help and will update when i get a volt meter on those batteries
Good luck!
The cab blower will work, but I believe the sleeper will not.
