2013 Volvo D11 Engine Fan stays On
Discussion in 'Volvo Forum' started by koolaid6666, Oct 15, 2019.
  1. koolaid6666
    koolaid6666 Bobtail Member
    15
    2013 Volvo day-cab with a D11, the engine fan constantly stays on did a 250 mile trip and stayed on the whole time its real annoying especially when it downshifts sounds like a jet landing. Just doesn't shut off.Any tips on what to check?
  2. Newto Trucking
    Newto Trucking Medium Load Member
    357
    215
    Dec 26, 2013
    NE Illinois
    Do you have manual or electrical fan. Do you see airline going to the fan housing. Can you turn the fan by hand when engine not running??
  3. koolaid6666
    15
    I will check tonight when I go in. I know there is a wire coming off it into a harness. It's a wire not a air line
  4. koolaid6666
    15
    There is a wire the goes to the fan. I can turn the fan by hand has a little resistances.
  5. Newto Trucking
    357
    215
    Dec 26, 2013
    NE Illinois
    Looks like this. And cable connects to the plug on a side of the alternator.
  6. koolaid6666
    15
    Yup
  7. koolaid6666
    15
  8. Newto Trucking
    357
    215
    Dec 26, 2013
    NE Illinois
    The same fan I have on my truck. Usually it comes on trucks with XE package. With a Volvo software you can see the percentage of engagement of this fan, it’s always spinning just at different speed, when you don’t need it it’s at around 20%. Whenever you start cold truck it’s usually engaged at 95% which sucks in a winter when you trying to warm up the truck ASAP. Other then a test drive with a laptop connected and monitoring that percentage of the engagement can’t tell you how to test them.
    KB3MMX Thanks this.
  9. koolaid6666
    15
    I unplugged and still stays running. I have another truck and it goes on and off like is suppose to. I run it with the a/c off and defroster off and it still stays running. This truck i have to recharge the Freon every year around spring time It has a small leak somewhere that know-body can find. Can it be a Freon problem?
  10. Newto Trucking
    357
    215
    Dec 26, 2013
    NE Illinois
    There’s no Freon in contact with this fan, you can try to add a dye to the Freon and see if you can find a trace of it where it’s leaking. You can always retrofit air controlled fan clutch on this engine.
    KB3MMX Thanks this.
  • Draft saved Draft deleted
