2013 Volvo D11 Engine Fan stays On
Discussion in 'Volvo Forum' started by koolaid6666, Oct 15, 2019.
  1. Newto Trucking
    Newto Trucking Medium Load Member
    359
    226
    Dec 26, 2013
    NE Illinois
    Here’s part number of my fan clutch on 2013 truck. 85115602=>23150081=>23585940. First one is original next two superseded part numbers. Google them, it might help you find more info online
    KB3MMX Thanks this.
  3. koolaid6666
    koolaid6666 Bobtail Member
    17
    OK thanks.Borrowing a scanner this weekend to read it snap on pro link
  4. KB3MMX
    KB3MMX Road Train Member
    3,076
    2,596
    Dec 29, 2014
    Orrstown, PA
    This is an Electronic Viscous fan BTW ..
    I tried to option the normal heavy duty 2 speed air operated fan clutch on my 2020 XE but they only allowed the viscous fan...IDK why Volvo is doing this.
    I like the idea that you can ramp the rate up and down but the problem is viscous fan clutch has generally don't last nearly as long as a heavy duty 2 speed air operated clutch.
    Newto Trucking Thanks this.
  5. Bold Group
    Bold Group Bobtail Member
    22
    19
    Apr 23, 2019
    How did you fix your fan? Test or replace? We have same issue. 2012 Volvo D13 electric fan constantly on.
  6. plasticVNL670
    plasticVNL670 Bobtail Member
    5
    Sep 28, 2010
    Will it be possible to replace the electronic fan for an air operated?
    I have a 2012 and the shop replace the whole assembly but still won’t engage.
    The volvo shop told me that I have to reprogram the new one but they won’t touch my truck because it a deleted unit.
    I just don’t know how to make this thing work
  7. Burdisco
    Burdisco Light Load Member
    120
    53
    Apr 25, 2015
    kitmaster makes air fans. Take a look at this, it's the work shop trouble shooting manual for volvo electric fan.
    plasticVNL670 and QUALITYTRUCK Thank this.
  8. RoadRanger^^
    RoadRanger^^ Medium Load Member
    318
    121
    Apr 17, 2018
    Columbus, OH
    On volvo with d13 engine check f9 fuse in the engine fuse compratment es2 if blown, if not check plug that supplies power to the solenoid( key on), if power is okay take out the solenoid and check resistance with mutlimeter, if not resistance change solenoid most likely bad. Resistance should be something around 0.379
