2014 Mack CXU rear diff gear oil?
Discussion in 'Ask An Owner Operator' started by xairx, Sep 17, 2019.
  1. xairx
    xairx Light Load Member
    100
    91
    Jun 24, 2019
    I'm looking to change the gear oil in my Mack. The dealer said $350 per diff just for the oil. I'm gonna do the job myself but... what oil would you recommend? Seems like almost any synthetic lube oil 75W-90 should do. What do you guys use?
    I'm very interested in the Sinopec GL-5 75W90. It's almost three times cheaper than Mobil1. Has anybody used it before? I did some research on it and it appears to be up to standard...
  2. Atlaw4u
    Atlaw4u Medium Load Member
    451
    657
    Jun 8, 2018
    That's on my to do list and I'm planning to use Sinopec. You can get 5 gallon tubs shipped to you from E bay if you can't find it locally.
    xairx Thanks this.
  3. xairx
    100
    91
    Jun 24, 2019
    I did some more reading and ordered Sinopec. Apparantly Mobil is not on the list for a reason. It causes slippage.
  4. Ridgeline
    15,823
    61,750
    Don't use mobile one, use sinopec. We had two axle failures with mobile one and Mack said it is why they didn't recommend it.
    xairx Thanks this.
  • Draft saved Draft deleted
