2014 Volvo losing power at certain speeds.
Discussion in 'Volvo Forum' started by Navreetgill, Apr 29, 2021.
  1. Navreetgill
    Navreetgill Bobtail Member
    8
    Apr 29, 2021
    My 2014 volvo d13 is losing power at some speeds. Some times its just struck at 55kmph sometimes at 70kmph but it never goes over 95.
    I have new turbo and replaced filters and injectors on truck. Dpf is deleted. What else can it be any suggestions??
  3. pavrom
    pavrom Road Train Member
    3,022
    6,873
    Apr 29, 2012
    NE illinois
    I had similar issue with freightliner ...it happened to be battery connectors loose
    Navreetgill Thanks this.
  4. Navreetgill
    8
    Apr 29, 2021
    Did you had any electric power loss as well? Because i never had any electric
  5. Navreetgill
    8
    Apr 29, 2021
    Added when try to speed up it will sound like power jerks and it shakes at front
  6. Truckwork2461
    Truckwork2461 Bobtail Member
    47
    14
    Feb 10, 2021
    When you replaced the injectors and turbo did they check the egr cooler, egr valves? Are you getting any ecu faults?
  7. aussiejosh
    aussiejosh Road Train Member
    4,654
    5,274
    Aug 28, 2009
    Airlie Beach QLd
    Yes my first thought was its a process of elimination however looks like you've already done that with the filters did that include the air - cleaner filter, if that's clogged up it'd certainly restrict your power. Next thing if you've done all of that is the fuel injector's depending on how many miles/km you've done if the pistons and rings are wearing out you could also lose power however you'd also notice it chewing up quite a bit of oil if that was the case. New or re-conditioned turbo check to see if that's also working properly.
  8. Navreetgill
    8
    Apr 29, 2021
    Update so issue was with trucks air to air.
    We replaced charge air cooler truck is running as new now.
    86scotty and QUALITYTRUCK Thank this.
