2014 Volvo VNL 670 Block Heater Plug location?
Discussion in 'Ask An Owner Operator' started by Rosepatita, Feb 9, 2021.
  1. Rosepatita
    Rosepatita Bobtail Member
    5
    Hi,
    I am trying to locate where the block heater plug is on my 2014 Volvo VNL 670... I have a D13 engine. This truck didn't come with a manual and the only plug I see is under the sleeper bunk and it says Cab Power. I looked by the passengers side bumper and didn't see anything there. Help!!
  3. loudtom
    loudtom Road Train Member
    1,640
    2,611
    Aug 26, 2016
    My plug is under the driver's side door area. On my D16, the block heater is up high on the passenger side, towards the front of the engine. The cord is a weird metallic colored, insulated looking one. If you have one installed, you should be able to trace it to where the socket plugs in.
    Rosepatita Thanks this.
  4. 86scotty
    86scotty Road Train Member
    3,930
    10,222
    Aug 27, 2017
    Appalachia
    You probably don't have one if it isn't obvious on the front of truck or under driver's door. Mine doesn't have one, it's a 2015 Volvo.
  5. Rosepatita
    5
    I am trying to find what it looks like online to make sure I know what I'm looking for. I'm starting to think I do not have one.
  6. Rosepatita
    5
    Does anyone have a picture of what it should look like?
  7. Rosepatita
    5
    Also, the problem is I am in Chicago and my truck is frozen, so I rented a generator to plug it in, but no luck. Any tips on what else I can do if no block heater?
  8. DUNE-T
    DUNE-T Road Train Member
    6,380
    15,000
    May 10, 2015
    Detroit, MI
    You can get couple of heating blankets, a heating pad for the oil pan and maybe something else. Google "how to unfreeze a diesel engine".
    Heck I have even seen guys putting a portable electric stove under the engine
  9. loudtom
    1,640
    2,611
    Aug 26, 2016
    Turn the ignition on and wait for the truck to do its checks, then instead of turning the key forward, push the key inwards towards the steering column. You should see a little icon light up on the bottom left of the dash. That will preheat your intake air. As soon as the light goes out, start the truck and it should fire up a bit easier. You will have higher than normal oil pressure, but once the truck warms up it will return to normal.
  10. 86scotty
    3,930
    10,222
    Aug 27, 2017
    Appalachia
    Never heard of that one Tom, so I just tried it. No light on my dash. Tried twice.
  11. Rosepatita
    5
    I will definitely give this a try
