Anybody else have problems with these stupid surge tanks and the coolant level sensor. This particular truck has had three surge tanks in the last six months. Some how the tank stops sending a signal to the sensor and although the tank is full, the truck shuts down thinking it's empty. I've tried changing sensors and plugs but the only thing that ever works is putting a new surge tank on and they aren't cheap. Any ideas what may be causing these to fail. Maybe this truck emits some weird magnetic signal that demagnatizes the surge tank? I'm at a loss
2015 579 MX 13 surge tank issues
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by FdEF, Mar 27, 2019.
You using OEM reservoir or aftermarket? Grime in tank usually causes float to stick. If you trust your driver, a magnet taped to the sensor works too.
Oxbow, pushbroom, magoo68 and 1 other person Thank this. -
Every paccar mx13 I’ve driven and a bunch of friends have low coolant codes in cool weather upon startup unless you overfill it .
Oxbow, spsauerland and Goodysnap Thank this. -
spsauerland and magoo68 Thank this.
Just a thought, try a dab of RTV on new sensor when installed or zip tie. Had 2 where heavier than normal vibration (damper) caused the "placement nubs" to wear more than normal allowing then sensor to drop down over time and give false "low" reading even though the tank was good.
I have a 2019 T680 with the same problem. I hacked a solution to the problem with a magnet and 2022 version of baling wire. All alarm lights and sounds are off and truck runs fine. Just do your precheck and eyeball the antifreeze reservoir, keep an eye on your engine temperature gauge and use your nose to sniff out any antifreeze odor. You don't need no stinking low coolant sensor. Pics are attached.
