2015 680 won’t heat up.
Discussion in 'Kenworth Forum' started by JK680, Feb 7, 2021.
  1. JK680
    JK680 Bobtail Member
    7
    Feb 6, 2021
    Hi new to the forum,just picked up a 2015 680 with the MX 13. Temperature will not get any higher than 125 and not blowing much heat. Wondering if thermostat might need to be replaced. Thanks
    Trucking Jobs in 30 seconds
  3. kemosabi49
    7,340
    24,996
    Jan 13, 2013
    SW Arkansas
    Probably does. You're not doing that engine any favors running with the temps that low either.
  4. PoleCrusher
    PoleCrusher Road Train Member
    6,181
    67,018
    Aug 26, 2014
    LLMF
    It's possible. You can take a big piece of cardboard, stick it between the CAC and radiator. Take it for a drive and see if it heats up. If so, then you have a thermostat stuck open.
    Flint1 and cke Thank this.
  5. JK680
    7
    Feb 6, 2021
    Ok thanks for the reply, hopefully not a major job.
  6. JK680
    7
    Feb 6, 2021
    2 new thermostats did the trick.
  7. God prefers Diesels
    1,793
    7,379
    Jun 26, 2020
    South Texas
    Thanks for the follow up. Many just roll on and leave the thread hanging.
    Flint1 Thanks this.
  • Draft saved Draft deleted
