Hey guys I have a 2015 Cascadia and I went from a single to dual antenna set up on the truck. What is the best way to get the swr reading down. It's currently around 2.3 on the duals. I was running a single around 1.5 and getting 1.3 on the stock antenna.
2015 Cascadia Dual antenna high swr
Discussion in 'CB Radio Forum' started by Blazen_toast, Jun 6, 2018.
Not to be a smart ### but go back to a single..
If you tuened each antenna exactly the same,test the coax,ant stud and mounts..Then chk coax and be sure its 75 ohm for duel ant and mot 50 ohm which is for a single..
What did you find when you did this?
