2015 cascadia no power to fuses for all 12v outlets and fridge. checked fuses and all are good.
Discussion in 'Freightliner Forum' started by Griff's Garage LLC, Sep 22, 2019.
  1. Griff's Garage LLC
    Griff's Garage LLC Bobtail Member
    PNDB shows relays are bistable and I am wondering fuse 29 3amp controls this but some relays work fine controlled by this fuse.
  2. Anywhichwaybutloose
    Anywhichwaybutloose Light Load Member
    73
    120
    Jun 24, 2017
    Did something trip the low voltage shutoff? I had a 13 that would shut all the 12v items off till the voltage would go back up. And even then it would take a while for it to reset.
  3. Griff's Garage LLC
  4. snowwy
    snowwy Road Train Member
    17,321
    9,209
    Jul 6, 2009
    FL isn't know for their best wiring on those sockets.
    There's power. Just no amps.
    Dealer fixed some bad ground wires. According to the work order. But those sockets didn't last.
    I used those 12v cooking ovens sold at the truckstops. Those are killer on them sockets.
    Had to use my 400 watt socket invertor just to charge my cell phone using the ac method.
    I had a 12 and a 16 FL.
  5. Griff's Garage LLC
    I had a gps plugged in and an auxillary fan which come with truck from the factory. I have never tried a device bigger than the gps and fan. When I supply power to the fuses manually all of my circuits work fine. I just want to fix it correctly.
  6. snowwy
    17,321
    9,209
    Jul 6, 2009
    I don't know.
    Just that dealer fixed ground wires. Sockets worked again but didn't last.
    Both trucks had that problem. And were 4 years apart.
  7. truckdriver31
    4,958
    5,386
    Sep 18, 2013
    why not wire you a good power source from the battery. if you are a good cooker. then you will have a good source.
    mhyn Thanks this.
  8. mhyn
    mhyn Road Train Member
    4,255
    4,386
    Dec 29, 2008
    Northridge, CA
    here you supply power manually? what fuses ?
  • Draft saved Draft deleted
