2015 cummins international prostar foot pedal problem
Discussion in 'International Forum' started by Tattoo777, Jun 25, 2024.
  1. Tattoo777
    Tattoo777 Bobtail Member
    Jun 23, 2024
    Hello i have a 2015 international prostar cummins about a year ago code came up for the foot petal sensor replaced it 2 days later problem came back light came off i just left alone and it ran fine for about a year now its just bucking really hard but once i get up to speed cruise controll works fine i cant see any wires that are cut or anything loose if anyone has an answer please help
  3. Goodysnap
    Goodysnap Road Train Member
    3,790
    9,227
    Jul 12, 2017
    You have 2 pairs of 3 twisted wires going from the pedal sensor to the ECM. You most likely have an intermittent open or short to ground in the wiring outside the cab and somewhere near the engine. Start with a thorough visual inspection of every inch of the harness at all contact points. Look for exposed copper even though it may be just barely thru.
  4. Tattoo777
    Jun 23, 2024
    Ok ,thanks. im going to inspect the wires. I also notice my engine break doesn't want to work all keep u posted
    Goodysnap Thanks this.
