2015 FL Cascadia transmission
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Keepontrucking2016, Oct 12, 2019.
  1. Keepontrucking2016
    Keepontrucking2016 Light Load Member
    164
    39
    Apr 7, 2016
    I does not happen often once in a while this happens I check engine light comes on for a second and then turns off mostly in the morning. I got lucky to take a pic of the codes n transmission shifts in every gear loaded or empty or takes a second to go in gears I called stealership they said mite be your split pin bushings which cost 40 and the rest is labor 1k or more has anyone encounter this see pic I think it's my shifter which is around 500 n easy to replace MVIMG_20190918_151309.jpg MVIMG_20190918_151259.jpg
Draft saved Draft deleted
