This is crazy I'm on the side of the road waiting for tow because my truck wouldn't turn off even with the key out.
It reaved up to 2000 rpms and smoked so bad somebody called the fire department and police. If finally shut off on it's own but, I thought it was gonna blow up.
What could this be?
2015 prostar won't turn off and revs to 20 Rpm and smokes
Discussion in 'International Forum' started by Truckmovin, Jul 7, 2017.
Wht engine? It almost sounds like a run away motor. But you said you reved it up
Cummings engine
Turbo seal went most likely and it ate its own oil .. not looking good unless it was a freak electronic issue
Could be stuck injector or turbo seal. Was it white? Don't let it run away if so you will be rebuilding engine
Push in the clutch, put it in 9th gear and ease out slowly...it'll stall. Sounds like an ecm gone nuts issue, Skynet taking over your machine...or 18 wheel version of "Christine"(old 80's movie about a possessed car for those of the younger generation)
Kenworth 4life, KB3MMX, Spartan0229 and 1 other person Thank this. -
Can't wait until hackers start playing with the ELD trucks that are tied to cellular or satellite data connections LMAO
Direct truck ECM access through the ELD
.Kenworth 4life Thanks this. -
Where's Paul Harvey it would be nice to know the rest of the story
Heavyd Thanks this.
