2015 T-680
Discussion in 'Kenworth Forum' started by DustyRoad, Feb 27, 2015.
  1. DustyRoad
    DustyRoad Road Train Member
    1,540
    17,104
    Feb 23, 2011
    Gulf of Mexico
    Help!:biggrin_25510:
    Need to know what how to over-ride shutdown on T-680
    My APU is out of service...bunk heater works but motor wont start---green flashing light on thermo king controller
    So when I need to idle....what is the sequence? Idle has 5 min delay shutdown.
    Set Brake?
    Set Cruise ?
    What else????
    Thx in advance...
  3. lmcclure1220
    lmcclure1220 Light Load Member
    170
    101
    Jan 18, 2015
    Walnut, Ms
    I can't say I know much of what I'm talking about other than the Volvo we used at class. We just hit the cruise button while it was idling and it held.
    DustyRoad Thanks this.
  4. skootertrashr6
    skootertrashr6 Medium Load Member
    639
    6,942
    Jan 4, 2012
    Pueblo, Co
    If you have already tried all that stuff, only thing left to do is take it to dealership and have them turn off the idle restriction in the computer.
  5. Tenn I See Trucker
    Tenn I See Trucker Medium Load Member
    556
    389
    Dec 19, 2013
    TULLAHOMA,TN
    Bump the accelerator when it starts to say idle shutdown on the info screen, I have a 2013 T680 and thats how to overide mine, if that doesn't work then your comany may have the truck set not to idle.
  6. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    On the T680, there's an ambient air temperature sensor... the probe can be seen sticking out of the bottom of the LH mirror assembly.. IF ambient air temperature override is enabled, there are ways to manipulate that (hand warmers, etc).
    There isn't one be-all, end-all answer here... it really comes down to a matter of how the truck settings are set by the company. If they don't want you idling that truck, they can disable all the override options. Ambient temperature override is the one most likely to not have been disabled.
  7. 04SSHD
    04SSHD Light Load Member
    110
    53
    Feb 7, 2011
    Henderson, NV
    seeing posts like these make me happy I don't drive for the big freight haulers. I can idle mine all day, every day.
    Raiderfanatic Thanks this.
  8. tazman74
    tazman74 Light Load Member
    254
    119
    Feb 27, 2013
    Albert Lea, Mn
    Not sure if it's the same as my 14 but turn the knob on the dash and shut the idle level to 0 that's what I did.
