Hi,
I have 2015 volvo 730 with i-shift. When I put it into drive (D) the truck does not move. When I put it into neutral it feels like its going into reverse. There are no fault codes in diagnostics. The truck has 780,000 miles. I had a problem few times before where the truck wouldn't go into Drive. I would then have to turn off the engine and turn it back on again and it would continue to work. I have also had issues with speed sensor and replaced them. Also fixed the wiring on the battery terminals recently because truck was losing power. What can be the problem please help? I hope I don't need a new transmission. Thank you for all your help!!!
2015 volvo 730 i-shift Transmission not going into Drive. Please help!! Thanks
Discussion in 'Volvo Forum' started by sdulku, Apr 11, 2020.
you can disconnect the batt. for 5 min. and try it again, try not to turn off the eng. in gear?
sdulku Thanks this. -
I tried disconnecting the battery it didn't work. Thank you Baha
Check the fuse for the tyranny (I would check them all). If there were no other prior issues with it, like gears grinding it could be a gear selector (usually gives you message on your dashboard) or electronic gremlins (wires, sensors etc.)
most likely something is either going on with selector in the truck or possible top cover on trans but if it was top cover it wouldn't make sense selecting wrong gear i would check selector in dash first than go from there but hard to tell without seeing it.
Volvo dealer gave the following codes: Split engagement system (p107177), counter shaft brake/input shaft brake (P107694), clutch plate load actuator slipping(P106074), and brake switch code(P105594). -
thank you F. Fernandez -
sdulku said: ↑Hi,
I have 2015 volvo 730 with i-shift. When I put it into drive (D) the truck does not move. When I put it into neutral it feels like its going into reverse. There are no fault codes in diagnostics. The truck has 780,000 miles. I had a problem few times before where the truck wouldn't go into Drive. I would then have to turn off the engine and turn it back on again and it would continue to work. I have also had issues with speed sensor and replaced them. Also fixed the wiring on the battery terminals recently because truck was losing power. What can be the problem please help? I hope I don't need a new transmission. Thank you for all your help!!!Click to expand...
Did you solve the issue? Please tell me. I have same problem
Related Categories
Volvo vnl d12 j1939 data link...
Larellsharell posted Apr 11, 2024 at 5:45 AM
CHECK DIAGNOSTICS alarm
Hkench posted Apr 5, 2024
Volvo vnl 670 d13 2017 throwing...
RoadRanger^^ posted Apr 4, 2024
Over weight on steers
thatguyfrombk posted Mar 30, 2024
Wheel Stud question.
MIg25 posted Mar 26, 2024
VNL860 fridge operation
thatguyfrombk posted Mar 25, 2024
Volvo jake break code
Cruzindown80 posted Mar 22, 2024
volvo vnl 2020 rear cab light
Calebdriver posted Mar 13, 2024
What’s this switch for?
Rideandrepair posted Mar 4, 2024
Best gear ratio for 15 speed
416autohauler posted Mar 1, 2024
Loading...
Recent Threads
Physical cost at minute clinic
Lav-25 posted Apr 17, 2024 at 2:19 PM
Alternative Finance Options
The_SnowMan710 posted Apr 17, 2024 at 1:21 PM
2015 Kenworth T680 tilt...
winged hussar posted Apr 17, 2024 at 1:04 PM
SAP/NO EXPERIENCE
Smokey&theBandit posted Apr 17, 2024 at 12:03 PM
How to do it in Chicago
dosgatos posted Apr 17, 2024 at 9:14 AM
Dump truck insurance question.
Keepforgettingmypassword posted Apr 17, 2024 at 7:52 AM
Semi Knocks Out Wall On NJ Turnpike
mjd4277 posted Apr 17, 2024 at 2:26 AM
Fatigued Or Distracted
mjd4277 posted Apr 17, 2024 at 2:17 AM
Logging Truck Rolls Backwards
mjd4277 posted Apr 17, 2024 at 2:08 AM
Cattle Hauler Bails After Steer...
mjd4277 posted Apr 17, 2024 at 2:06 AM
Loading...
