you can call me 3 4 7 3 9 1 9 3 3 9
SALE!!!! Price for the whole package $27000. before it goes to central america.
Freightliner cascadia evo 2016
Utility trailer 53 ft swing doors xd4000 2008
Trailer pass inspection for food grade Trailer.
This truck is one of its kind, here is new parts and the set up on it.
Has Oil sampler history show in that the engine is in excelent condition.
I have proof history on both.
Truck has 762k miles.
Engine is a DD15
Eaton fuller MANUAL 10 speed
6x2 set up (lighter truck and you can lock Differential and drop air bags if you need)
truck has the EPA system in place - (Not Deleted)
I own this truck for 4 years. Here is what I have done on it.
Reman Eaton fuller manual 10 speed transmission
New cluth
Air compressor
Gear box
Power steering shaft
Power steering reservoir
Power steering pump
Steering wheel column
Alternator
Starter
Radiator
Water pump
Coolant Reservoir
Crankcase breather
QVC
def pump + def filters every 6 months
King pins
Tie rods + bar
Thermostat
Air valve throttle
Differential seal
Dpf filters
Nox sensors
Bushings front and rear axles
Ac condenser
Update coolant/air/AC hoses
Replace pretty much all air valves/solenoids
oil pan
Easy Oil drain plug
Oil pump
Oil suction tube
Drums
Brake shoes
Brake chambers
Wheel Bearings
Wheel seals
Fifth wheel
New fuel rail
Tune up 1 month ago
Airflow mudflaps
Tire rack for the truck and trailer
Brand new tire continental 295/80r22.5 with aluminum wheel for spare emergency.
New baterries
Annual DOT inspection
Pretty sure I'm forgetting much more things that I have done. I have proof receipts.
Here are the amenities on this truck
Heater wipers
Legacy comfort seat with arm rest.
Minimizer heavy duty floor mats (covers 70% of the cab floor)
Alligator battery charge (never need a jumper)
WeBoost driver reach otr cell phone booster
3 Security/dash cam recording with a 11 inch screen ( you can watch 360° trucks surrounding)
Tundra 1500 inverter
Espar Heather bunk
OEM fridge
14000 btu whynter AC and Heather full set to be run with a generator
Block hearther and water separator heater can be run out of a generator ( no cold starts)
Update interior lighting
It has right Weigh scale in the truck and trailer with its gauges
Orange lug nut securement ( no lug nuts falling off)
For the trailer is a utility xd 4000 2008 53 ft dry van.
I pretty much renew this trailer. Also have proof of receipts
New air tank
Bushings
Wheel Bearings
Wheel seals
Shocks
Drums
Brake chambers
Brake shoes
Right weight scale
Replace 2 board floors on the deck.
Truck has only one seat due the set up for the AC, toilet, sink and shower. The original seats were sold.
2016 Freightliner cascadia evo semi truck + dry van xd4000 swing door - $27,000
Discussion in 'Trucker Forum Classifieds & Trading Post' started by Loscargo, Sep 22, 2025.
