2016 glider 12.7 96 engine smokes at start under 30 degrees
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 4noReason, Dec 8, 2025.
  1. 4noReason
    4noReason Road Train Member
    2,392
    752
    Nov 29, 2012
    truck. in cold cold. Will struggle to start or not start if below 20 unless hooked to electric heat block. batteries alternator starter new. it smokes heavy white smoke. if its 40 degrees it will stop after warm. but in cold 30 below it will not stop smoking. at start up smoke so bad it looks like a fire is happening. what do you think are reasons? it was like this before and after overhaul. injectors all new too.
  3. Big Road Skateboard
    6,775
    38,129
    May 2, 2021
    Low compression pistons.
    And you said 30 below. Did you mean below 30*, or -30*?
    Is engine coming up to over 150* after warming up?
    Rideandrepair and 4noReason Thank this.
  4. Star Rider
    Star Rider Road Train Member
    1,694
    15,968
    Sep 23, 2019
    It's called winter with a diesel engine.
    Normal.
  5. 4noReason
    2,392
    752
    Nov 29, 2012
    ya 30 degrees and below it. Engine does warm up. so if piston compression low what can I do?
    Rideandrepair Thanks this.
  6. 4noReason
    2,392
    752
    Nov 29, 2012
    no all trucks in my yard don't act like this
  7. Star Rider
    1,694
    15,968
    Sep 23, 2019
    How old are the engines in the other trucks?
    Every one of the 90s era Detroits we got in our shop in the winter smoked like a freight train and sounded like it was coming apart on startup.
    Bean Jr., Rideandrepair, Oxbow and 2 others Thank this.
  8. blairandgretchen
    13,755
    74,935
    Dec 9, 2011
    South west Missouri
    Mine is the same - 12.7 1995.
    I shut it off overnight, and run the generator and block heater all night below 25f.
    If not, it looks like a dumpster fire.
  9. blairandgretchen
    13,755
    74,935
    Dec 9, 2011
    South west Missouri
    Yup - like a bunch of elves with hammers under the hood for 5 minutes.
  10. Big Road Skateboard
    6,775
    38,129
    May 2, 2021
    Well, even below 30*, the smoke should ease up once the engine gets to operating temp.
    You can set it to half mode with a Pro Link or lap top. That'll cut fuel down till it gets warm. It'll start and smoke for a second, then you can hear it kinda miss, and the majority of the smoke goes away.
    It'll then hit 125* and you'll hear the engine tone change. It's getting a little more fuel. Then at 150*, the engine will sound normal.
    That’s just a fix to cut down on the smoke during cold starts.
    The only real fix is installing the higher compression pistons.
  11. 4noReason
    2,392
    752
    Nov 29, 2012
    good to know lol
