2016 international lonestar right side instrument panel not working
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by trenten02, Oct 2, 2024.
  1. trenten02
    trenten02 Bobtail Member
    20
    Apr 21, 2011
    monroe,wi
    Right side isn't working which includes radio cigarette lighter and none of the toggle switches light up..was going out periodically and always coming back on..now nothing..seemed to be fine first 3 or 4 hours of driving in the morning every day then would start going off and on.any suggestions
  3. MRMTRANS
    MRMTRANS Medium Load Member
    352
    386
    Apr 28, 2015
    Optional Instrument cluster fuse out? I had it happen in my truck. I have Instrument Cluster and Optional Instrument fuses. It was Optional one. Instrument powers the necessary instruments like water temp, air guages, oil pressure, etc.
  4. trenten02
    20
    Apr 21, 2011
    monroe,wi
    Where is that fuse located
  5. trenten02
    20
    Apr 21, 2011
    monroe,wi
    Nothing works here
  6. MRMTRANS
    352
    386
    Apr 28, 2015
    I don't know where the fuse panel is located on a International. Somewhere under the dash on the passenger side I imagine. Fuse panels are usually easy to access. Maybe just pulling off a panel.
  7. trenten02
    20
    Apr 21, 2011
    monroe,wi
    I don't think it could be a fuse.. It was tripping in and out periodically , but now Nothing comes on unless it's some type of relay that would reset itself.That went bad
  8. MRMTRANS
    352
    386
    Apr 28, 2015
    I've had relays that work intermittently. So maybe
  9. 201
    201 Road Train Member
    12,138
    24,776
    Apr 16, 2014
    high plains colorado
    I never could warm up to the styling of the Lonestar, and rarely saw one in the Badger. Monroe cheese hauler? Hauled a lot out of Swiss Colony. You probably don't have many fuses and all circuit breakers, I think. Something, maybe dash dimmer is getting hot and tripping the breaker. Truck is too new to have ground issues, whatever gets the most use, like headlight switch, trailer lights, anything plugged into lighter port can get hot too. Good luck.
  10. trenten02
    20
    Apr 21, 2011
    monroe,wi
    Well that's where i'm from monroe.. That's what it almost seems like 'cause.It would work fine in the morning and then It would start tripping off and on When I was running for 3 or four hours.. So I'm assuming it has to be some kind of relay that resets itself just don't know where it would be.
  11. Heavyd
    Heavyd Road Train Member
    7,752
    6,186
    Feb 4, 2009
    They all share the same battery feed A14K, 8 gauge red wire. This feed separates to multiple smaller 12 gauge wires which supply battery power to fuse locations, F2-B, F2-C, F2-R, F2-L, F2-N, F2-G, F2-J, F1-D, F9-E, F2-B, F3-C. There might been a bad crimp at this main split.
