2016 Peterbilt 579 vents not cooling
Discussion in 'Peterbilt Forum' started by tuckerroadtrucking, Jul 11, 2022.
  1. tuckerroadtrucking
    tuckerroadtrucking Bobtail Member
    My defroster works just fine and it blows cool air on the feet but with the A/C blowing through the front vents - its not cold. I checked and it seems like my evap line may be freezing. what can I do next?
  3. kranky1
    kranky1 Road Train Member
    2,228
    8,645
    Sep 16, 2015
    Ontario, Canada
    Let some gas out of it. If it’s freezing up it may just be over-charged. I started leaving my W900’s down an oz or oz and a half from the 2lb spec. They still blow cold but quit freezing up and blowing compressors off themselves every year.
  4. tuckerroadtrucking
    Looks like I just needed to add Freon. Also did a computer reset.
  5. AModelCat
    128,445
    If you're getting adequately cold air out of all other vents except for the dash vents then I'd start checking the blend doors/actuators.
  • Draft saved Draft deleted
