2016 VNL780 D13 Crankcase Breather dripping oil
Discussion in 'Volvo Forum' started by Generictrucker, Jan 14, 2022.
  1. Generictrucker
    Generictrucker Light Load Member
    85
    41
    Jul 25, 2013
    Tullahoma, TN
    Looking for help here, as I'm at my wits end with this truck.
    The other night, I parked and idled for about an hour. After turning the truck off, I noticed a huge oil slick that apprears to be coming from the Crankcase Breather on the side of the motor.
    Would this be a gasket or the crankcase itself going bad? Thanks in advance!
  3. QUALITYTRUCK
    1,667
    1,574
    Jun 14, 2009
    romulus,mi
    Replace the whole unit. Very common repair. Save your wits end for when you need it.....
    Generictrucker and 86scotty Thank this.
  4. 86scotty
    86scotty Road Train Member
    3,278
    8,043
    Aug 27, 2017
    Appalachia
    Agreed ^^^. Just needs to be replaced. I did mine about 750k and it was a few hundred if I remember right. No problems since.
    Also, don't try to clean it as some people say. There are Youtube vids on this but it doesn't work for long. You'll have to replace it all sooner or later.
    Generictrucker Thanks this.
  5. Socal Xpress
    1,819
    1,898
    Dec 6, 2014
    Los Angeles, Ca
    Like Quality said just replace it. Has the spinner ever been replaced? They don't last forever.
  6. Generictrucker
    85
    41
    Jul 25, 2013
    Tullahoma, TN
    It's weird, it doesn't leak all the time, and when it does doesn't seem to happen at the same time. Sometimes it's a few minutes after I fire the truck up, other times, it's 20 minutes, sometimes, it doesn't leak at all. It's definitely coming out of the valve, but this doesn't make sense to me.
  7. nasriza
    nasriza Road Train Member
    2,198
    1,791
    Feb 1, 2013
    Chicago, IL
    these #### spinners get stuck inside and this is what happens most of the time they will leak during regen, just replace breather and gasket and it should be good.
  • Draft saved Draft deleted
