2017 Wabash air backfeed? Check valve? Pressure Protection Valve?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Joeziah, Dec 30, 2020.
  1. Joeziah
    Joeziah Light Load Member
    153
    114
    Jan 2, 2016
    When I set my trailer brakes I get a big blast of air backfeeding into my truck, almost like the trailer's air tanks are emptying out of the red glad hand back into my truck's system.
    It actually causes my trucks brakes to not set if I pop both valves at the same time until most of the air seems to bleed out of the trailer.
    There seems to be a pressure relief valve on the inlet side of the trailer's air tank, I'm wondering if that has gone bad? Is there a 1 way valve somewhere on this thing?
    Also, the button you pull to inflate the sliding tandem bolt release will reset if you don't sit there and hold it until what seems to be the majority of the air is dumped from the system.
    Is it that little valve on the side of the tank that has gone bad? Part # is VS-1128 Pressure Protection Valve
    Would this cause these problems?
  3. Goodysnap
    Goodysnap Road Train Member
    3,502
    8,383
    Jul 12, 2017
    The VS pressure protection valve most likely supplies air to your air suspension or another regulated device.
    Air most likely charges the tanks through the main emergency brake valve. You are correct that it should not bleed off the entire tank of air to empty. This one way check valve is most likely not servicable seporately and youll have to replace the whole valve.
    Been a long time for me on trailers, so please school me if Im wrong here.
    black_dog106 and Joeziah Thank this.
  4. little cat 500
    1,950
    1,004
    Jan 17, 2010
    Abbottstown PA
    last time mine did that it was the tractor protection valve
  5. Joeziah
    153
    114
    Jan 2, 2016
    VS-1128 valve sits on the supply side of the air tank from the looks of it, seems to be the only valve I can see between the truck supply and the air tanks on the trailer.
    This is the only trailer it does it on, I've pulled 2 others, so not a problem on the truck side I assume.
  6. flood
    flood Road Train Member
    4,023
    3,761
    Dec 25, 2010
    It's a valve on the trailer... You know the valve that dumps the air in the trailer brakes when you pull the red.(you hear it dump) When it goes bad it will back bleed the air back thru the truck also in the cold the valve can freeze
    Joeziah Thanks this.
