We're having trouble with the rear lift axle (steerable) wobbling while the trucks moving 15mph+. We had all the bushings, shocks and tires replaced on the axle a few days ago an had the air pressure adjusted. The new shocks have already blown out so looking for any advice as to what could be the issue. We've also had the bearings and kingpins inspected.
2018 Peterbilt 389 isx15 rear lift axle wobbles horribly
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Jerrywalters, Feb 15, 2019.
Pictures?
Jerrywalters and BoxCarKidd Thank this. -
Alignment?
Jerrywalters, pushbroom and spsauerland Thank this. -
What is toe set @ and what down pressure running in ride bags.
Jerrywalters and pushbroom Thank this. -
No pictures? Try getting a stabilizer.
Jerrywalters Thanks this. -
Sorry been busy with some other stuff . What kind of pictures would u like? Pressure been tested between 45 and 65 with same issue. We're gonna trying adjusting toe when we get the chance today
Tire balance?
By your picture it is a Watson Chalin lift axle. You can find their manuals online and they have a load/pressure chart. We run ours around 60-65 psi on quad and quint axles with the 12K and 13.2K lift axles. They recommend 1/32 of toe, I always made it a strong 1/32 or more of a 1/16.
Jerrywalters, BoxCarKidd and pushbroom Thank this. -
Problem has been solved. We were replacing the rear shocks with the monroe brand which apparently cant handle the loads we haul. After replacing them out with original Watson Chalin shocks, all the trucks with the wobbles are now riding smoothly. Thanks for the replies and help
BoxCarKidd and Tombstone69 Thank this.
