2019 cascadia fuel gauge reading
Discussion in 'Freightliner Forum' started by DonJuan76, Aug 31, 2019.
  1. DonJuan76
    DonJuan76 Bobtail Member
    Just filled up and before I even left the truckstop gauge is reading 1/8 tank less....been that way 3 months now....fuel sending unit been changed twice....any suggestions?
  3. Powder Joints
    7,162
    6,734
    Sep 25, 2007
    Rosamond, SoCal
    Bend the wire to the float down a little bit , not much just a little
  4. bigkev1115
    bigkev1115 Road Train Member
    2,363
    3,608
    Oct 23, 2009
    Alexandria, AL
    Most Cascadia s fuel needles are usually off a little. I ve driven every generation Cascadia and the needle shows about anywhere from 1/8 to as much as 1/4 off even in my 2020 model
    mhyn, gearjammer42 and magoo68 Thank this.
  5. drivingmissdaisy
    drivingmissdaisy Road Train Member
    1,374
    2,361
    Jun 10, 2019
    Mine does the same thing. Our shop upgraded our software and now its better.
    You also may not have truly topped off the tanks. If you let the nozzle stop on its own it can leave 10-15 gallons off of a truly full tank.
    D.Tibbitt Thanks this.
  6. Powder Joints
    7,162
    6,734
    Sep 25, 2007
    Rosamond, SoCal
    you can adjust that by adjusting the float arm, easiest to do with a full fuel tank, pain in the butt though.
  7. ast26909
    ast26909 Medium Load Member
    408
    263
    Mar 1, 2018
    I don't think there's an adjustment that can be done, it's an electronic sensor there is no float.
  8. tarmadilo
    tarmadilo Road Train Member
    1,372
    3,487
    Dec 12, 2018
    The important part is how accurate it is at the other end!
  9. D.Tibbitt
    130,560
    My 2016 fuel gauge doesnt work at all . yellow light has been on for over a year , im surprised it aint burned out yet lol i just use the leg meter to track miles and gallons used. Its pretty accurate for most part. Sometimes its off by 20 gallons or so if i idle alot. Say i used 80 gallons driving and idle on a 34 break it will say on leg meter 110 gallons or so but go to fill up and might only be 95 gallons to top off. For some reason it doesnt record idle gallong usage very accuratly. But if no idling and just driving its surprisingly accurate. It has never left me stranded. I have 150 gallon tanks. 130 is my cut off. When it gets to 120 im searching for fuel if i cant make my scheduled stop
  10. ast26909
    408
    263
    Mar 1, 2018
    Fix it, the part is around $100 it's not that hard to change out.
  11. D.Tibbitt
    130,560
    Aint my truck . i avoid putting my truck in shop for stuff that aint life or death. Not worth the lost money for downtime.
    LoSt_AgAiN Thanks this.
