2019 Hyundai trailer axle seals leaking
Discussion in 'Experienced Truckers' Advice' started by 401-Alex, Feb 27, 2020.
  1. 401-Alex
    401-Alex Light Load Member
    251
    275
    Nov 25, 2013
    401
    I bought a 2019 Hyundai dry van in 2018 it had 650 miles on the hub odometer. As of 2/20 it has 150,000 miles on it. @ 40k it needed all 4 inner wheel seals. 10k later it needed one again. Now 100k later it has had one replaced again and has 2 more that are seeping again. I am the original owner so it is under warranty no charge other then my time waiting for it to get done. If it needed to be fixed on the road it would be my bill and no compensation for a defective trailer. I do not want to get an OOS because it keeps on leaking at random. I also have never gotten anything as far as repair. Invoices or anything even though I have asked every time and requested to have them emailed to me. What can I do?
    truckdriver31 Thanks this.
  3. Opendeckin
    Opendeckin Medium Load Member
    390
    1,011
    May 20, 2018
    Maybe switch to grease instead of oil bath?
    truckdriver31 and Bakerman Thank this.
  4. 401-Alex
    251
    275
    Nov 25, 2013
    401
    It is under warranty for the next 5 year's. I imagine if I were to go your route I'd be buying 4 hubs . it has a tire inflation system so that might be hard. I work on my own truck and have done all 4 drive wheels seals and bearing I am 100k + on 2 of them and wonder how I can do it right on an 05 tractor but the dealer can't on a 2019. Are the axles defective?
  5. AModelCat
    145,184
    Couple possibilities. I'd be curious what they set the bearings at for endplay. Too much and they'll leak. Poor installation or even a hub/axle defect are another.
  6. 401-Alex
    251
    275
    Nov 25, 2013
    401
    I had heard that Hendrickson had kale tubes that were not 100% true round and were more oval this was a defect. I'm wondering if I got them? I don't know how they installed the seals or what endplay they have
  7. truckdriver31
    6,986
    8,340
    Sep 18, 2013
    does it have usa dot rims. we got a ton of new trailers with china dot rims. had to switch them out
  8. 401-Alex
    251
    275
    Nov 25, 2013
    401
    They are galvanized steel wheels
  9. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,077
    Sep 24, 2019
    Raleigh, NC
    May have them switch them to painted steel. Or at the very least mark where the tires are and what seals blow out.
    If the tire is out of balance that will kill your wheel ends
  10. 401-Alex
    251
    275
    Nov 25, 2013
    401
    All 4 seals ? They were all virgin hankook tires. And at under 40k on miles needing all 4 seals to be replaced. That is crazy I see the truck rolling down the highway withe what looks like a bent wheel but its is a crooked recap that is wobbling
  11. kemosabi49
    10,007
    41,470
    Jan 13, 2013
    SW Arkansas
    Bent wheel or crooked recap. Either way the wobbling will tear up the wheel seal eventually.
