2020 internatioanl - cummings engine - FLYWHEEL SOUNDS/Noise ?
Discussion in 'International Forum' started by JerryD13, Apr 29, 2023.
  1. JerryD13
    JerryD13 Light Load Member
    167
    124
    Oct 17, 2016
    Good Afternoon drivers, 2020 International / cummings engine
    So I have a sound coming from the transmission - FLYWHEEL - most likely
    truck has 340.000 miles and runs very good --- this FLYWHEEL SOUND / noise -- just
    started about a month ago and it seems like it may be getting worse.
    ** The noise is not all the time just once in a while.
    What would you recommend
    -- to get this corrected -- and what would be the best approach
    for this type of problem.
    The sound comes on generally when in 10th Gear 50 mph + - going downhill.
  3. JoeyJunk
    JoeyJunk Road Train Member
    7,397
    51,759
    Dec 31, 2010
    Washington, PA
  4. JB7
    JB7 Medium Load Member
    340
    410
    Dec 13, 2022
    In order to determine the cause, one of the most useful tools we have used is the Steelman Smart Ear. This tool uses a series of clamped wireless transmitters that are attached to various vehicle components, and a receiver that the technician can use to listen to the noises generated by those components.
    Some of these type of tools will also tell the frequency of the noise to narrow down the possibilities. Other than that the transmission would have to be pulled to check the pilot bearing (goes in the center of the flywheel) etc. What is the warranty on the trans? Some Eaton trans used in linehaul the warranty is 5 yrs 750k miles.
    JerryD13 Thanks this.
  5. InternationalExpert
    InternationalExpert Bobtail Member
    10
    5
    Mar 1, 2022
    are you sure its from the flywheel? could it be from the gearing in the trans? id think a flywheel would make noise all the time if that is where the sound is coming from.
  6. JerryD13
    167
    124
    Oct 17, 2016
    Excellent response - never knew about the Steelman Smart Ear many thanks
    Heavyd Thanks this.
  • Draft saved Draft deleted
