2020 T680 - radio locks up and delay in cruise/light switches.
Discussion in 'Kenworth Forum' started by F4T6UY, Nov 10, 2019.
  1. F4T6UY
    F4T6UY Medium Load Member
    567
    1,807
    Oct 24, 2017
    Very South Texas
    So the company bought a bunch of 2020’s back in March. My truck is not the only one doing this.
    the radio will occasionally just freeze in whatever mode it’s in at that time. If you’re listening to an FM station or cd or whatever, at whatever volume, then pull up to weigh station - you can’t turn the volume down, you can’t even turn the radio off. Turn the key off the ignition, and the lights are still on on the radio. It will do this randomly. Some times daily, sometimes once a week. The only thing I know to do is to stop and pull the cb/radio fuse.
    Also, I have a delay in some of my switches. It’s about a quarter to half second delay in my headlights. And my cruise resume sometimes as well. cant help but think these are related to the radio issue.
    I’ve talked to multiple drivers that are having the same issue. The shop is aware of it. Took it to the Kenworth dealership a couple of months ago and they had no clue Asked the shop about it last week, and they still don’t have a fix.
    Somebody’s gotta know something.
  3. pushbroom
    pushbroom Road Train Member
    1,788
    7,393
    Sep 1, 2012
    There is a recently released update for the smartnav system. It should be able to install through the device update app from the homescreen.
    Switches will need the modules flashed at the dealer.
    Isafarmboy Thanks this.
  4. F4T6UY
    567
    1,807
    Oct 24, 2017
    Very South Texas
    Appreciate the response.
  5. Topmeoff624
    Topmeoff624 Bobtail Member
    I know this old but I googled this and it brought me here. New job, new 2020 t680. My switches are fine. My issue is the radio freezing. I’ve been cutting the power off the battery to fix this and it seems to work but then my AC doesn’t work unless I let it sit for like 10 mins after cutting the power to battery to on position. Where are the fuses? Or better yet, you know where I can find a diagram so i can know what fuse is which.
  6. Leviathan Tube
    Leviathan Tube Medium Load Member
    305
    140
    Mar 21, 2014
    Georgia
    Fuse for the radio is by your left foot. Locations are labeled inside the cover. I have to pull mine every now and then because I have the same issue and, as is typical, if the problem is not acting up when the truck is at the dealer, they won't do anything.
  7. Capacity
    Capacity Road Train Member
    1,499
    3,119
    Jul 28, 2019
    Neenah Wi
    I had the same issue only Dealer that fixed it correctly is Palmer KW , Indianapolis.
  8. Rsanchez
    Rsanchez Bobtail Member
    What was the fix for the radio issue?
  9. Topmeoff624
    I ended up finding the radio fuse and one quick pop out and pop in and you’re back rolling. Fuse box is located to the left of your feet. The door to the box tells you what fuse
  10. Leviathan Tube
    305
    140
    Mar 21, 2014
    Georgia
    Get ready to do that on a regular basis. It's not a permanent fix.
  11. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    You can unplug S-can cable or get to dealership for radio software update or go to pana pacific website, support center and go to downloads and go to DEA5xxx software update.
    Leviathan Tube and QUALITYTRUCK Thank this.
