2021 cascadia cruise will not engage after a stop like taking a break.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by slim shady, Sep 16, 2021.
  1. slim shady
    slim shady Road Train Member
    3,464
    14,605
    Sep 14, 2011
    Chicago, Il.
    Can anyone explain why my cruise control works fine after a 34/10 hr break but every time I stop and start rolling again it wont engage, tried hitting the brakes.
    Got no clutch it's an auto. Very frustrating
    I know my old KW youd hit the brakes or clutch and it would engage
    4mer trucker Thanks this.
  3. ibcalm19
    ibcalm19 Road Train Member
    1,440
    2,404
    Nov 30, 2015
    Pennsylvania
    I had the same problem for a couple of times so far. I'm trying to pin point it too. It will start working as I'm driving. It happened to me twice last week. It didn't do it this week so if I find out anything I will pass it along.
    slim shady Thanks this.
  4. Flyingdriver
    Flyingdriver Bobtail Member
    34
    103
    Oct 29, 2020
    Walla Walla WA
    I drove a 2021 Cascadia with the same issue. It would go weeks & the cruise would work just fine then without warning it would not engage. It always would engage within 15 minutes of so of driving but it was frustrating when it wouldn't. My truck had a little over 100,000 miles on it. Not driving it anymore.
    A couple of times I pulled over, shut off the truck for a minute or two & it would work just fine. I'm sure it was a computer glitch.
  5. 401-Alex
    401-Alex Light Load Member
    251
    275
    Nov 25, 2013
    401
    Try a hard brake application before you start driving. My Volvo is an 05 and sometimes at random cruise doesn't work. Took a while to figure that it needed a hard application to "reset" it's ability to cruise again. Especially if you're easy on the brakes off the highway to park
    Magoo1968 and slim shady Thank this.
  6. Ross_Tech
    Ross_Tech Light Load Member
    133
    133
    Aug 31, 2021
    Okay, so there is a couple of things this can be. Wabco has an update for the ABS ecu if yours is on the list(attached). There's also a service solution from DTNA (google SS 1033950-couldnt attach). And finally check your 7 wire to make sure the trailer abs power isn't being interrupted when you go over bumps. And if you pull the same trailer, check the trailer to make sure the power to the ABS ECU is good.
    Magoo1968 Thanks this.
  7. slim shady
    3,464
    14,605
    Sep 14, 2011
    Chicago, Il.
    Thanks for that
    Now the last driver of the truck covered the adaptive cruise control sensor.
    And I've left it that way. Could that cause this issue, it was fine but lately I cant engage my cruise. Normally after I shut down for my 10, it works in the morning
    But not today no cruise at all
  8. Ross_Tech
    133
    133
    Aug 31, 2021
    If you're talking about the front radar, It will prevent adaptive cruise control operation. And you'll get faults for radar blockage, but you should get an option for standard cruise.
  9. slim shady
    3,464
    14,605
    Sep 14, 2011
    Chicago, Il.
    I get the warning "debris blocking radar"
    But was able to override that.
    I'm about to bobtail now I'm going to try the cruise
    Ross_Tech Thanks this.
  10. slim shady
    3,464
    14,605
    Sep 14, 2011
    Chicago, Il.
    Bobtail cruise worked, hooked different tank cruise worked again, maybe need new pig tail?
    bzinger Thanks this.
  11. Ross_Tech
    133
    133
    Aug 31, 2021
    Yea, or the pins were wore out on the last trailer.
    bzinger, Magoo1968 and slim shady Thank this.
