I'm trying to find a good parts resource online for Volvo parts. Of course, Volvo doesn't want to give this info up. My local dealer may or may not tell me the part numbers of certain things so I can shop elsewhere but on some things I need to shop online and do the work myself and save some money.
For instance, 2021 VNL 860. How do I find out what front (disc) brake rotors and pads I need? I cannot find this info online. No year/make/model searches on most sites. I understand why this is on trucks that are spec'd so specifically but I can't afford to have a dealer do stuff like this.
Anyone know how I can find out what front brakes I have short of pulling them off? Hub must be pulled to access these rotors. Pads are old enough to probably have no print on them.
2021 VNL brakes and parts
Discussion in 'Volvo Forum' started by 86scotty, Sep 23, 2023.
Heavy Duty Truck Parts | Class8TruckParts | Volvo, Mack Truck
I think they are the dealer in Wheeling, WV. They've always been helpful giving me parts numbers in the past when the other dealers are hesitant to.86scotty Thanks this. -
If I was at the yard I would give you the part # for the pads. Can get them at most parts stores.
If you have to change a rotor, junk the con met and use meritor. -
If the rotor is still in spec then just leave it. If it's cracked/out of spec replace with a Meritor. -
This is the only problem I've found with their DOT on the truck so it's not the end of the world. -
