2022 T680 Transmission
Discussion in 'Trucks [ Eighteen Wheelers ]' started by moybutter, Jun 20, 2025.
  1. moybutter
    moybutter Bobtail Member
    38
    35
    Jul 16, 2018
    For the first time since I've been driving this truck it wouldn't accelerate when I hit the pedal and then a little while later it accelerated but it was stuck in 9th gear.
    I pulled over and removed the transmission fluid reservoir cap and I did not see any fluid and smoke was coming out of the hole.
    When I resumed driving a little while later the truck accelerated and the gears shifted normally.
    Am I low on transmission fluid? There is no dipstick on the cap I did not see any fluid leaks on my pre trip. Thx
  3. mitrucker
    mitrucker Road Train Member
    5,500
    10,394
    Dec 15, 2010
    Lapeer, MI
    Most likely an electronic issue.
  4. engine_900
    engine_900 Bobtail Member
    20
    22
    Jul 16, 2021
    Vancouver, BC
    how many miles on the transmission box? Try replacing the tranny fluid first since its the least expensive and most common cause.
    moybutter Thanks this.
  5. AModelCat
    165,049
    Most of these automatics are just automated manuals. Changing the oil isn't going to do much, it's not like they're a true automatic with clutches, bands and a torque converter.
  6. OlegMel
    OlegMel Medium Load Member
    617
    1,048
    Apr 8, 2023
    There should be a sight glass on side of the transmission to check fluid . Try disconnecting batteries for 30 minutes, sometimes you’ll get a ghost code or some random bs code that will trip the computer.
  7. Lazer
    Lazer Road Train Member
    1,850
    2,983
    Jan 22, 2017
    Check your alternator for funky ‘charge spikes’ that can raise all sorts of havoc with auto-shift transmissions.
  8. moybutter
    38
    35
    Jul 16, 2018
  9. moybutter
    38
    35
    Jul 16, 2018
    I have approx 362k miles on the truck and I am a company driver. I haven't had a repeat of the issue so I believe that it was just an electronic glitch as someone previously mentioned.
