2023 FRHT Cascadia. Left turn signal blinking fast and not working when connected to a trailer.
Discussion in 'Freightliner Forum' started by rcc_209, Aug 26, 2023.
  1. rcc_209
    rcc_209 Bobtail Member
    Hello everyone!
    I need your help to figure this one out. I have a 2023 Freightliner Cascadia, when I put the left turn signal it starts clicking fast and when its connected to any trailer it doesn't work, the light is on, but there is no flashing when activating the left turn signal.
    I already tested the 7way connector on the back of the cab and I know for sure its an issue with the truck. We changed the SAM chassis, it got fixed but now it stop working again.
    Has any of this happened to any of you guys? Thanks!
  3. drivingmissdaisy
    drivingmissdaisy Road Train Member
    1,171
    2,046
    Jun 10, 2019
  4. LUNDRYJEFF
    LUNDRYJEFF Bobtail Member
    19
    Aug 26, 2023
    I HAD AN OLDER TRUCK DO THAT IT WAS A BAD CONNECTION ON THE ALTERNATOR WIRE
  5. SWM_TECH
    SWM_TECH Light Load Member
    114
    118
    Apr 15, 2018
    You may want to do some voltage drop testing on the ground path to the sSam. Path is battery to Mega Ground Junction Block (MGJB) to outside ground frontwall pass-through-stud to the Inside Ground Frontwall Pass through stud to the sSam. After, testing you may find that cleaning & tightening the connections points where you have the biggest voltage drop beneficial. I have seen some trucks where the red enamel cable sealer was put on cables ends before final assembly, rather than after final assembly and was creating high resistance. Please update us with your results.
    QUALITYTRUCK Thanks this.
  • Draft saved Draft deleted
