2023 VNL 860 D13 Failed DPF Pump
Discussion in 'Ask An Owner Operator' started by Siinman, Oct 1, 2024.
  1. Siinman
    Siinman Road Train Member
    5,181
    13,040
    Mar 5, 2017
    Kansas City, MO.
    Just wanted to post this so others can compare if need be. I have right at 280K on the truck and the other day had a check engine light come on.
    Ended up dead heading home from Texas because of #### rates and that light made me a little worried. But the rates was the main issue. Took to shop this weekend and had them figure it out. Was putting a fault code out
    SPN-4334 J1939 2 Aftertreatment 1 Diesel Exhaust Fluid Doser 1 Absolute Pressure
    Shop got it all fixed this morning and replaced the DPF Pump. All is good afterwords but might help someone else out later down the road if this comes up on your Volvo.
    Constant Learner Thanks this.
  3. wichris
    wichris Road Train Member
    4,246
    8,493
    Jan 17, 2011
    Both off mine have bad ground issues, have run grounds direct from battery to different modules to fix.
    Siinman Thanks this.
  4. 86scotty
    86scotty Road Train Member
    4,415
    11,752
    Aug 27, 2017
    Appalachia
    @Siinman, not to be picky but do you mean DEF pump?
    Siinman and Diesel Dave Thank this.
  5. Diesel Dave
    8,573
    23,851
    Jan 20, 2010
    Hesperia, Ca.
    Do you mean the sending unit inside the DEF tank ?
  6. Siinman
    5,181
    13,040
    Mar 5, 2017
    Kansas City, MO.
    Ha Ha Yeah it is the DEF pump. Wrote that and did not even see I had a Typo. Thanks for the correction.
    86scotty Thanks this.
  7. Siinman
    5,181
    13,040
    Mar 5, 2017
    Kansas City, MO.
    Yes. Had some brain issues evidently. Ha Ha
    Diesel Dave Thanks this.
  8. Siinman
    5,181
    13,040
    Mar 5, 2017
    Kansas City, MO.
    I might have a similar issue going on. I noticed the last few weeks or so that my inside light when opening door does not turn on right away. Takes 10-30 seconds sometimes. Use to turn on right away or within a couple seconds. Might be a grounding issue maybe? What all did you see causing problems on your issue?
  9. AModelCat
    155,460
    Door switch isn't sticking?
  10. Siinman
    5,181
    13,040
    Mar 5, 2017
    Kansas City, MO.
    I do not believe so. Does so on both doors.
  11. wichris
    4,246
    8,493
    Jan 17, 2011
    Volvo says everything is fine. LOL
    I just ran a ground wire direct from the battery to the cab. Only need about 10" wire, there is a bracket hanging down from the cab right above the battery
    just grounded to that.
    If you have dash problems, pull F53 & F54 fuse, wait a couple of minutes and re-install. Volvo's solution to that. LOL
    77fib77, Siinman and 86scotty Thank this.
