I recently had a driver reach out to me with a concern of heat coming out of his 2024 Cascadia. Somewhere there is enough heat that came out on the driver side to deform the lower fairing on the driver's side. We have inspected everything we can possibly inspect and cannot come up with a reason as to why this happened. Has anyone else seen or heard of this happening before? If so, what were you able to find as a cause? Hopefully my pictures are able to be viewed.
2024 Cascadia Heat Concern
Discussion in 'Freightliner Forum' started by Wrenchit25, Jun 30, 2026.
Is it just me or does that upper bracket look bent? Not sure heat caused that.
Magoo1968 Thanks this. -
Unbolt one bracket and see if it straightens out . A bracket may have gotten bent forcing plastic to bend .. or possibly parked next to a grass burner with a side exit exhaust who happened to do a burn at that time.. I can’t think of anything on your truck that would get that hot on drivers side..
Arctic_fox and OldeSkool Thank this. -
Heat deformity usually happens on the passenger side when the DPF filters are not sealed properly. There is no exhaust plumbing on the driver's side so I don't know of anything that would melt the fairing. There are some large and very important plastic air lines on the driver's side. Any of those, get damaged? Anything else underneath the cab get damaged?
I tend to agree with the above comment that it is probably a dent.OldeSkool Thanks this. -
Pretty much this. There is nothing on the drivers side of most trucks that even gets hot enough to deform plastic. MAYBE if you have stacks and one has a leak. But that would more likely melt near to the exhaust pipe. That looks way more like a dent or MAYBE a grass burner beside him did it. But dent soneplace is the most likely cause.Magoo1968 Thanks this.
Unbolted everything and nothing is bent and the fairing stays the same shape. I wondered about him parked next to a grass burner as well, but he says he hasn't parked next to anyone this week. His pretrip photos prove that as well, so somehow this happened while he was driving.
Uhh that's not heat, the looks like something hit it, maybe road debris or when backing..
Tire carcus debris if hit could definitely bend the fairing like that.....
It's just odd that when we unbolt the fairing it keeps that shape. That's where we were thinking heat, but I guess anything is possible.
