379 King pin issues (pictures attached)
Discussion in 'Ask An Owner Operator' started by Yayomaez379, Mar 10, 2022.
  1. Yayomaez379
    Yayomaez379 Bobtail Member
    13
    30
    Mar 9, 2022
    Northern Ohio somewhere
    I’m coming here to ask advice from the more experienced. Two weeks ago I had my King pins, steering knuckles, tie rod assembly, and rear spring bushings replaced on my 2005 PB 379. Also had a three axle alignment done along with new steer tires. Noticed yesterday my steering would get hard but only when I was stopped or rolling really slow. This morning as I was backing into a tight dock steering got hard and makes one heck of a binding noise. At first I thought it was the steering box headed south on me. Upon further inspection I noticed the keepers on the king pins were loose. I tightened them down (both sides) and now my steering is super tight and every time I turn the wheel no matter at a stop or rolling at any speed I get that binding sound. It’s not good. Gotta deliver this load in the morning then head back home to take it back into the shop. Can somebody please explain what is going on and would this be on the shop that did the work?? I forked over a little less then 8k to have the front end rebuilt less then two weeks ago. Your advice and help would be greatly appreciated. Kinda lost and do not know what the #### to do or how to handle this issue with the shop. 39B33F94-FF59-4860-A089-FC3D170DE6DE.jpeg 39B33F94-FF59-4860-A089-FC3D170DE6DE.jpeg 89329249-76A7-4D16-B0F5-5B2C5ECCAA36.jpeg 1C648D7B-A024-428C-8B28-11C1104FEAA3.jpeg
  3. Big Road Skateboard
    7,296
    41,601
    May 2, 2021
    May be something other than king pins, but I doubt it. Maybe try greasing them to see if it helps. Sound like they didn't ream the bushings correctly.
    Mike250rs, Vampire, Bean Jr. and 2 others Thank this.
  4. Yayomaez379
    13
    30
    Mar 9, 2022
    It’s bad. Even worse when I tightened it down. Like a grinding, binding sound.
    Bean Jr. Thanks this.
  5. Big Road Skateboard
    7,296
    41,601
    May 2, 2021
    Definitely king pin related if tightening them made it worse.
  6. Upstatetrucker
    Upstatetrucker Bobtail Member
    29
    96
    Nov 15, 2020
    My springs were worn out on a 2018 T680 at 450,000 Miles. Under load they would make a popping noise at low speeds going into a corner. Replaced the springs and shackles and that fixed the problem. Not sure if it's related but worth a look.
    Vampire, 77fib77 and Yayomaez379 Thank this.
  7. Yayomaez379
    13
    30
    Mar 9, 2022
    Yea there is no popping noise. Spring bushings are new as well.
    Vampire Thanks this.
  8. 77fib77
    77fib77 Road Train Member
    11,814
    78,370
    Jul 7, 2010
    St Louis
    Why are the bolts cut on one side?
  9. Big Road Skateboard
    7,296
    41,601
    May 2, 2021
    The king pin has a cut machined in it where those bolts go. Keeps the king pin from moving
    Vampire, Yayomaez379 and Last Call Thank this.
  10. 201
    201 Road Train Member
    12,873
    26,497
    Apr 16, 2014
    high plains colorado
    KING PIN KEEPERS WERE LOOSE?? I'd dig up Telly Savalas and go meet and greet the shop you took it to. Unacceptable, and downright dangerous.
    mitmaks, Vampire and Yayomaez379 Thank this.
  11. Yayomaez379
    13
    30
    Mar 9, 2022
    So after I tightened the keepers, the steering was real tight. Made and binding noise every time I turned. Got a load headed home from Indianapolis to Columbus Ohio. As I’m pulling into my delivery making a left hand turn the wheel got real tight and could not turn the full radius. So I stopped, turned the wheel, backed up and went to pull into driveway again. Wheel got real tight then gave way. The binding noise is gone. I got pretty scared so I checked in and tilted the hood. All looks well and keepers are still tight. Nothing I can see is broken. After unloading I have roughly a 100 mile dead head to the shop. Wheel feels like normal now after backing into dock. Really odd, weird and scary in my book. Taking truck straight to shop and wife will pick me up. You are right sir, downright unacceptable and flat out dangerous
    shooter19802003, Vampire and Siinman Thank this.
