last 6:172482
engine harness schematic: P94-6098
cab harness schematic: P92-8332-00000
i have continuity everywhere.
wipers work on every setting, just no washer pump.
i have checked: turn stalk to CECU, yellow wire on washer pump back to pin 46 on firewall connector, from D3 on firewalll connector to pin 46 on "J50", and also from D3 (opposite side connection) on firewall connector to chassis node "C".
im sure i left a few wires out. i have countless hours tracking down this issue to no prevail. very frustrated.
as i said, i have continuity everywhere seemingly. the only issue im having is figuring out which fuse "powers" the washer pump. in the cab there is a wiper system fuse (good), 2 diodes for wiper system, multiple relays. everything checks out. where the hell does the pump get power from????? i willl never understand why a 2 wire washer pump needs to go through 3 ecm's, multiple connectors, relays, etc. etc. etc. ridiculous.
PLEASE HELP
386 Washer Pump NO POWER
Discussion in 'Peterbilt Forum' started by bmac211, Apr 29, 2020.
Pump is powered by G8 fuse on the firewall.
G8 goes to chassis node connector C pin 15. Most likely corroded wire by drivers cab mount.
Washer pump wiring is one of the longest circuits and jumps through multiple harness.
Let me know if you need more helpspsauerland, bmac211, 650cat425 and 1 other person Thank this. -
spsauerland, QUALITYTRUCK and pushbroom Thank this.
Can this be translated to simple driver language?
