2018 and 2020 567 Spare Switches
Discussion in 'Peterbilt Forum' started by Animosus, Jan 25, 2023.
  1. Animosus
    Animosus Medium Load Member
    656
    2,482
    Dec 7, 2015
    SE Wyoming
    We have a 2018 and 2020 567 with about 10 factory spare switches. I gather that these are all multiplexed and are not actual switches that you can tap directly into. So where did they hide all these outputs? There are a couple threads I've found but none have a definite answer and neither does the body builder manual. Is this something that has to be programmed with DAVIE? You'd think with all these #### switches it shouldn't be that difficult to use them for trivial little things.
    Oxbow Thanks this.
  3. QUALITYTRUCK
    1,780
    1,726
    Jun 14, 2009
    romulus,mi
    The switches need to be enabled thru ESA.
  4. Z800xp
    Z800xp Bobtail Member
    18
    Feb 26, 2019
    Pardon my ignorance but what is esa ? Always wondered about the spare switches
  5. QUALITYTRUCK
    1,780
    1,726
    Jun 14, 2009
    romulus,mi
    ESA is Paccar software used for diagnosis/programming of electronics mostly non-engine related.
  6. Z800xp
    18
    Feb 26, 2019
    Thanks for the reply. So pretty much a dealer thing ?
  7. QUALITYTRUCK
    1,780
    1,726
    Jun 14, 2009
    romulus,mi
    Not really. Many of us shop owners have ESA along with all of the other OEM programs. Almost impossible to run a successful repair business without them.
    D.Tibbitt Thanks this.
  8. Goodysnap
    Goodysnap Road Train Member
    3,502
    8,384
    Jul 12, 2017
    Your chassis may be different as well. The 2018 is surely ESA. The 2020 model may be VECU in which case is a VMux truck and the switches are done thru PVP and Davie. All digitaL dash and newer trucks=no more ESA
    bjytech, QUALITYTRUCK and D.Tibbitt Thank this.
  9. QUALITYTRUCK
    1,780
    1,726
    Jun 14, 2009
    romulus,mi
    Excellent point Brother. Got a bit ahead of myself.
  10. Diesel Dave
    7,309
    14,645
    Jan 20, 2010
    Hesperia, Ca.
    I have extra spare switches on my 2014, and I have insulating wiring with connectors that are tuck around different areas on the truck, like;, by the air cleaners, under the cab, under the sleeper, and by the front bumper. Just saying.
