Hi my name is Chris and I'm new to the forum. I'm building a bad boy 6nz and was wanting to use a lower NXS block. Any advice on pistons, front cover, cam, and 6nz tune?
Thanks!
6nz build with nxs crank
Discussion in 'Trucks [ Eighteen Wheelers ]' started by cswolley, Oct 3, 2019.
Page 1 of 3
Nsx crank will not work in a pre MBN engine. That is all I know.
Why not go big boy and build a 7nz??Rubber duck kw Thanks this. -
Intothesunset Thanks this.
As far as I know that is a thing that is done. Just make it into a C16.
I heard C16 have a tendency to crack liners.
From what I understand, you can go the 6nz route fairly easy with the acert block and crank, do some research.
To go the C16 route you would need a crank, and they are to my understanding big bucks, and the liners are a little thinner. If a guy was going to go that route, might as well go all out and use a C18 crank and liners.Intothesunset Thanks this. -
Look up KT3406e on Ytube.
Page 1 of 3
