85 KW 100E cab heat
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by dqtransport, Jul 24, 2021.
  1. dqtransport
    dqtransport Bobtail Member
    TN
    Does anyone have a schematic of the cab heat due to previous owner reassembled incorrectly causing me to have to heat or how to fix.
  3. roundhouse
    roundhouse Road Train Member
    1,069
    1,913
    Jul 11, 2018
    I don’t , but the wiring should be pretty simple for the blower fan ,
    They usually have one main power wire that runs through some resistors that are usually located inside the blower housing so they have air flowing over them ,
    and the routing for the water hoses is easy.
    plus you have several months before you’re gonna need heat.
  4. baha
    baha Road Train Member
    3,824
    2,389
    Jul 25, 2013
    ga
    If it does not have cut offs on the heater lines, now is the time to put but offs on both lines, The heater lever on the dash should lead to a cut off in the incoming heater hose line inside the heater box?
    Bean Jr. Thanks this.
  • Draft saved Draft deleted
