I will like to find out what a bad barometric sensor can do to a 3406E engine and also if somebody where is located at the engine.
99 international 9300 with 3406E "barometric sensor"
Discussion in 'International Forum' started by trucker359, Nov 8, 2013.
3406?? do u mean 466E
I mean cat 3406E 475 hp
http://www.thetruckersreport.com/tr...forum/34703-caterpillar-power-harness-37.html
The barometric pressure sensor aka "The atmospheric pressure sensor is an absolute pressure sensor that measures crankcase pressure. Both the boost pressure and the oil pressure are communicated to the service tools and over the data link. The two pressures are calculated by subtracting the reading for the atmospheric pressure sensor. The atmospheric pressure sensor measures pressure from 0 (0) to 116 kPa (17 psi). The atmospheric pressure sensor is supplied with + 5 VDC by the ECM." -CatterpilarWrench
hope this helps
