A/c not working in front but works in bunk
Discussion in 'Kenworth Forum' started by Vince_M, Sep 13, 2023.
  1. Vince_M
    Vince_M Bobtail Member
    Hi, I just got this 2005 t2000 a couple weeks ago and it seems the ac up front doesn’t work anymore but the bunk is still blowing cold. I’m getting warm air in the front. I’m hoping someone can tell me if this is an easy fix for a do it yourselfer. Thanks and keep on trucking!
  3. Rubberens
    Rubberens Bobtail Member
    42
    Dec 6, 2017
    Expansion valve on passenger firewall easy to do your self
  4. Transportauto
    Transportauto Light Load Member
    89
    34
    Apr 10, 2022
    Could be blend Door not switching,
    Grab the ac lines going into the firewall, one should be pretty cold other warm, if not then you have a stuck open txv or a blown through orfice tube. Set of cheap gauges will go along way
  • Draft saved Draft deleted
