abandment?
Discussion in 'Experienced Truckers' Advice' started by Generation Follower, May 16, 2013.
  1. Generation Follower
    Generation Follower Light Load Member
    93
    6
    Jan 5, 2008
    indiana
    Started with a company Monday. Took a load 40miles then picked up a load that was over on my axles. They said it was safe for scales. Also lied about my pay it was supposed to be hourly. Well it wasn't it was percentage. I parked the loaded truck at their terminal and quit walked away. Is this abandment and can they come after me? Or is it only abandment if its not on their property?
  3. brsims
    brsims Road Train Member
    5,275
    6,443
    Aug 8, 2009
    Meadville, PA
    Quit under dispatch. Almost as bad as abandoning equipment.
    But its not abandonment, since you left the equipment on their property.
    Still wouldn't give a busted egg for your employment chances after they are done DAC'ing the snot out of you, though.
  4. Jakaby
    Jakaby Medium Load Member
    428
    557
    Mar 25, 2012
    Grenada, Mississippi
  5. CDL1968
    CDL1968 Medium Load Member
    345
    207
    Sep 27, 2012
    USA
    Abandonment or tampering of equipment loaded or unloaded can be put on your drivers record with the state and DAC
    Quitting under dispatch loaded or unloaded can be put on your DAC, which you can fight to have removed. Sometimes it only takes a letter and some sometime is takes a lawyer, and sometimes you win and sometimes you lose. Some companies will claim you were under dispatch even when you truck has been in the shop for a week.
    While either one of these is showing on you driving record or DAC you will find it very hard if not imposable to find a driving job.
  6. Suncoast
    Suncoast Light Load Member
    166
    54
    Nov 18, 2008
    Tampa, FL
    Most likely your DAC will show Quit under a load. It is frowned on almost the same as abandonment. You should find another job NOW! before it hits your DAC.
  7. tl385
    tl385 Light Load Member
    81
    36
    Jul 2, 2012
    Copperas Cove, Texas
    Quitting under dispatch is never good. But this isn't equipment abandonment. Now I have heard of companies who have put "unauthorized location" on drivers' DACS even though the equipment was returned to the terminal. A certain driver mill in SLC has been known to do this in the past (you guess which one).
    Get another job NOW, and get a copy of your DAC in about a month and look it over real good.
  8. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    192
    Jan 31, 2012
    Green Bay Wi
  9. Ghost Ryder
    Ghost Ryder Road Train Member
    1,647
    1,180
    Jan 3, 2013
    Your Mailbox
    An employer in less than one week? If quitting under a loaded dispatch isn't bad enough, adding job hopping to your resume isn't much better.
  10. TripleSix
    111,026
    So, what was your percentage and the linehaul? If I signed on for $18 an hour and they gave me a load going 200 miles paying $1000 gross, and offering me 26%, I wouldn't complain.
  11. volvodriver01
    volvodriver01 Road Train Member
    Yes "quiting under a load" is bad, IF you plan on driving for the low paying mega carriers. If I were you I would drive for a reputable small company that doesn't use DAC as it is proven to be fed by lying companies that are out to hurt the working mans resume. Don't worry to much about finding another driving job as you shouldn't have to much of a problem doing so. Good Day.
  • Draft saved Draft deleted
