My current trailer has been to the shop for the ABS light being on. The mechanic says it's fine and it breaks fine. But it has a light on the trailer and the dash warning that the ABS is out.
Can I get a ticket for this? As I said it feels fine and doesn't lock up, and the shop said run it.
ABS light on the traioler & DOT
Discussion in 'Experienced Truckers' Advice' started by scott180, Aug 1, 2022.
Boondock, Flat Earth Trucker and D.Tibbitt Thank this.
Yes a warning ticket. Not OOS. If when you turn the key on, and hear it clicking 4 times, it’s working. If not it’s not working. Turn key on off on off on- then count the flashes on the trailer light. Number of flashes corresponds with location of the problem. If the light only comes on, stays on without blinking, the systems not getting power. If so, be careful, might lock up in rain, or sudden stops. Mechanic is a mechanic in job description only. He should know enough to fix the light, it’s fairly simple. Even for a shade tree like myself.
BigHossVolvo, High Stepper, ProfessionalNoticer and 6 others Thank this. -
Rideandrepair, Studebaker Hawk, snowlauncher and 8 others Thank this.
Take it to a shop that can actually tell you what’s wrong, many shops are clueless to how to figure an abs problem.
Bean Jr., Rideandrepair, Studebaker Hawk and 4 others Thank this. -
Bean Jr., ProfessionalNoticer, D.Tibbitt and 2 others Thank this.
I once passed a level one inspection with a trailer ABS light on. This after having taken it to the shop and being told as you were.
I'll bet you have a dirty sensor.Bean Jr., Rideandrepair, ProfessionalNoticer and 2 others Thank this. -
Rideandrepair, Flat Earth Trucker, ProfessionalNoticer and 2 others Thank this.
The initial simple check is to make sure your plug has proper power going to it, that it's working correctly. I'm having this problem with my truck, around 60% of the trailers I haul I'm getting a trailer ABS light, yes, a portion of them are junkers, but it's doing it with our privately owned equipment too. Boss checked it and cleaned out corrosion at last PM, when he get's back from vacation I think we're going to put a new end on it.
Rideandrepair, ProfessionalNoticer and Boondock Thank this. -
Rideandrepair, snowlauncher and JoeyJunk Thank this.
